I set up my fitbit on my windows 10 computer and it is not tracking my steps just calories. I also set it up on my Iphone and it is tracking the steps and calories. The calories on Windows 10 is different than on the Iphone what gives?
Hello @FredFudbuck, thanks for joining us, it's great to have you on board.
When you sync your tracker with your account, do you notice a discrepancy on the data showed on the computer and the iPhone? If not, my suggestion would be restarting your tracker and then sync it with your iPhone, then check the information on your online Dashboard on your computer, the information should now be the same.
To restart your tracker:
I hope this can be helpful, give it a try and keep me posted in case you need anything else! ![]()
