@jimfournier the Zip doesn't have the reminder to move function. You can see what it offers by going to the store and comparing the devices.
Best Answer@jimfournier sounds like you might want the Flex 2 or the Alta. I checked and both can come out of the band and will give you the reminder to move feature.
The Alta costs more and isn't waterproof like the Flex 2. The Flex 2 only has a series of dots, so there are no numbers to see, but if you use your mobile device, you can view the numbers on there.
Both have a tiny tracker that slips out of the band and can be put into a pocket or even placed in a holder. You could put the tracker into a small ziplock bag or rig up some sort of case and it would be fine. I've done this before with my original Flex and it does track the steps.
Glad you're finding ways to recover from this. Keep in touch.
Awesome help @Odyssey13! 🙂 Welcome to the Forums @jimfournier! I appreciate that you have shared your experience. As @Odyssey13 mentioned you can check out which Fitbit device is the best fit for you.
To do so, you can visit our comparison page Fitbit.com/compare. There you can select the features you like the most or you can take a small quiz that can help you to find the best Fitbit buddy for you.
I hope you get well soon! 🙂
