09-14-2017 15:19 - edited 10-10-2017 11:45
Fitbit update 10/9/2017: This has been resolved in update 2.41.1. Please update your app if you continue to experience this issue. Thanks again for your reports and patience. As this issue is resolved, I'll be closing this thread for further comments.
I've merged a few posts together because we received several reports of battery draining for Zip users on iOS after the 2.39 update. Our team is currently investigating the root cause of this issue and will be hard at work to get a fix out as quickly as possible to get you all back on track. Once I receive an update from them I will update this thread and will make sure to keep you all in the loop.
Also note, we have had reports that turning off all-day-sync has helped as a workaround and worth a try until this issue is resolved.
Thanks for your help with reporting this and for your continued patience.
Actively managing your weight? Find accountability buddies on the Manage Weight board
11-02-2017 03:10
11-02-2017 03:10
11-02-2017 03:58
11-02-2017 03:58
For me I believe the problem has been fixed. I do have auto sync turned off but I last replaced the battery on September 18th and it is still showing full despite being down to 25% during the 'problem' period.
Best Answer11-02-2017 05:28
11-02-2017 05:28
Oldguy48
hi. I’m a big fan also and I just couldn’t go away from Fitbit so I’m just patient but yesterday also I followed some suggestion from same Fitbit forim, is to put ur new battery with a small piece of paper at the back of the battery then cover it as usual It worked for me
Best Answer11-02-2017 05:49
11-02-2017 05:49
Best Answer11-03-2017 02:26
11-03-2017 02:26
For anyone who is using the laptop version of the app as a work round, mine showed that my Zip needed updating this morning and I stupidly updated it, thinking it would be a fix, but it made things worse! My zip went from showing full battery to half full, straight off. So, I would really recommend that you do not update your zip unless you are sure they have sorted the battery issue out *sigh*
Although, on the other hand, before the update, the solution had been working really well.
11-04-2017 13:03
11-04-2017 13:03
I have gone through 4 batteries in 2 weeks. Is there anything that has been resolved on this? I hate to have to Get rid of my fitbit, but at the cost of batteries, it is not worth it.
11-04-2017 13:13
11-04-2017 13:13
Best Answer11-04-2017 15:53
11-04-2017 15:53
Best Answer11-04-2017 18:24
11-04-2017 18:24
Best Answer11-04-2017 18:25
11-04-2017 18:25
So sorry. Mine is workin good for now and it’s been good for almost 3 weeks.
Best Answer11-04-2017 18:35
11-04-2017 18:35
11-04-2017 19:17
11-04-2017 19:17
Dee
i did all kinds of things from deleting the app to upgrading the phone to getting different batt to adding a little piece of paper inside with battery to make little pressure inside They were a suggestions from the forum and fitbits guidance. After all this witchy things also I put the lithium battery that’s what I’m using. I bought it al dollar tree. Just to see how much luck I had. But wait for Fitbit helps u, maybe they have ur solution for ur device
Best Answer11-04-2017 19:22
11-04-2017 19:22
Best Answer11-04-2017 19:35
11-04-2017 19:35
11-04-2017 23:28
11-04-2017 23:28
Best Answer11-05-2017 04:58
11-05-2017 04:58
After upgrading and trying different options listed out here, I've given up. Bought a non-fitbit device and moved on. Good luck to all of you.
