06-17-2015
21:14
10:08
HelenaFitbit
06-17-2015
21:14
10:08
HelenaFitbit
I use a zip so am unable to recharge the battery. Each time I put in a new
battery, it lasts a maximum of 1 month. The present battery was put into
the zip last Monday and by Thursday the zip was indicating that the battery
was almost nil. I followed the suggestions to make sure the toggles were
aligned properly so that the battery sat level and that improved the
battery life a bit but on Tuesday of this week I rec'd another message that
the battery should be replaced.
Ruta
03-01-2016 09:54
03-01-2016 09:54
@WilmaBlue Welcome to the Fitbit Community! Try to update your tracker to its latest version. You will find the instructions on that link. Also, here are some tips on how to maximize the life of your Zip's battery. Also, restart your tracker. The battery should work properly.
Let me know how it goes!
03-04-2016 09:01
03-04-2016 09:01
03-04-2016 17:37
03-04-2016 17:37
03-05-2016 04:50
03-05-2016 04:50
04-10-2016 17:54
04-10-2016 17:54
I changed by battery one week ago and today I had to replace it again. I have only owned it for a couple months and I have checked all the contacts which seem to be as described. I walked over 3 miles today and it says I have only taken 36 steps....it is proving to be a frustrating new toy.
04-10-2016 18:50
04-10-2016 18:50
04-10-2016 19:22
04-10-2016 19:22
I'm getting less than a month from a battery. A battery put in 4 days ago, shows medium. I tried all the trouble shooting suggestions. Nothing seems to help.
04-10-2016 20:55
04-10-2016 20:55
For me I had the problem, but things went back to normal when I got a small glasses type screwdriver and bent and played with the contacts until it looked like they had to be in contact. The one I worked on was the contact holding the battery in on the lower right side. it took some time, but it worked. I should have done like a lot of people and just called customer service and got a new one as there had to be some issues with quality control as I had to "mess around with the contacts" until I got it working.
I also noticed that the different batteries I bought did not seem to be exact as compared to each other. Very slight differences when drew circles on paper, weighed them and compared. Not sure if that has anything to do with it.
04-10-2016 20:59
04-10-2016 20:59
04-11-2016 09:04
04-11-2016 09:04
05-09-2016 08:06
05-09-2016 08:06
Qustion regarding fitbit icon:
The third icon after the time, a "chubby looking flame" appears, what does it mean. (Maybe calories?) When I walked from the bedroom to the kitchen, it gave me the number 399. Yesterday after a three mile walk, the "chubby face" recorded 1,300, but my nike app in my iphone, under calories is said 250.
Please let me know what the icon means. Thank you.
05-10-2016 15:39
05-10-2016 15:39
@elva1 Welcome to the Fitbit Community! That icon means the calories you have burned. You will see a number of calories everyday even if you have not moved, that is because the dashboard will calculate your BMR (Basal Metabolic Rate). The calories burned you see will be the actual calories you have burned for the day plus the ones burned through your BMR.
Hope this helps. Let me know how it goes!
06-17-2016 10:24
06-17-2016 10:24
06-17-2016 10:36
06-17-2016 10:36
06-17-2016 10:40
06-17-2016 10:40
06-17-2016 13:03
06-17-2016 13:03
06-18-2016 00:41
06-18-2016 00:41
My last batter has only lasted three weeks. I just looked at the symbol andit showed empty. the batteries used to last four months. This is ridiculous.
07-09-2016 17:29
07-09-2016 17:29
Received my replacement ZIP on May 30th. The battery died on July 9. No display at all and no update to the dashboard. After reading all of the posts concerning short battery life, I called customer support. They had me remove the battery and wait 10 seconds before reinstalling. Still no display. Voltage was 2.48V. Based on some of the posts, the display was always on causing a constant battery drain. After 1/2 hour, the voltage increased to 2.65V. I really don't want to take the battery out every night while I'm sleeping. I will turn off the smiley face; don't know if that will help.
07-16-2016 20:48
07-16-2016 20:48
07-19-2016 07:20
07-19-2016 07:20
