04-27-2017 08:13
04-27-2017 08:13
Changed from the One to the Zip last year (The "One died from old age) -- changing models was a BIG mistake -- the Zip went nuts on me within the year, and finally, after all "fixes" failed, it was replaced Nov2016. Then the battery died end Jan2017... installed a new battery (which took a few days to sync)... Now, April2017, battery is dead again !! Saw post about bend in post --- no obvious bend in mine...
No telling how long this one will last - might have to purchase battery by the case !!!
Not at all a fan of the Zip.. wish I had spent the extra $$ to get another "One"...
Best Answer04-28-2017 10:34
04-28-2017 10:34
Nice to see you here @my4aussies! I really appreciate your feedback about Fitbit Zip. Make sure that you are using is a CR2025 battery. Also, while you change the battery double check that the battery pins are like in the picture:
After this, please let me know to continue assisting you! 😉
