10-30-2016 16:47
10-30-2016 16:47
I have
*taken the battery out
*uninstalled and reinstalled the app on my computer and phone.
*I have updated my profile
*signed out and back in
Nothing is working. Also the time is incorrect! Any help would be very grateful please!! I don't understand why it keeps doing stuff like this!??
Best Answer10-31-2016 04:55
10-31-2016 04:55
Welcome to the Community @Andra123. Thanks for troubleshooting this inconvenience by yourself. If your tracker is not syncing, I recommend following @HelenaFitbit's instructions in the Having trouble syncing? post.
I hope this helps, let me know the outcome. ![]()
Best Answer11-01-2016 19:17
11-01-2016 19:17
Thanks for the reply. I had done all those things and none of them worked.
It is working again now after 2 days, I don't get it. Anyways hopefully it will keep acting right, other wise I will contact customer service about it.
Thank you!!
Best Answer11-23-2016 14:11
11-23-2016 14:11
@Andra123 thanks for the update! It sounds like you've exhausted all troubleshooting possible to fix this issue. You are right, the next step would be contacting our Support Team for a second opinion. They definitely have the proper tools to take a deeper look into your tracker's behavior!
Let me know how it goes! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
