09-04-2019 13:17
09-04-2019 13:31
09-04-2019 13:31
It's been over 3 weeks for me.
It will only sync after battery removal.
I have contacted support many times.
No solution.
It's extremely frustrating.
I have had a zip for over 6 years. Never any issues until now.
They had to change something. I have had same phone for 8 months no issues.
I don't want a watch..
I wish they would fix whatever the issue is
09-04-2019 15:38
09-04-2019 15:38
Ditto, ditto, ditto to everything Karen
Thompson said. I am extremely frustrated trying to get zip to sync and only will work if I take battery out and put back in. Fitbit please fix this problem soon!!
09-04-2019 16:05
09-04-2019 16:05
Yeah, mine fails to sync too, the same as others have said. Started just a few weeks ago. It'll sync if I reset it by removing and replacing the battery, but then it stops syncing again.
09-04-2019 16:31
09-04-2019 16:31
Yes, the ONLY way to get the zip to sync is removing battery and re-inserting. Then that only takes care of the moment - it doesn't last. If so many zip users are having this problem, I don't understand why Fitbit does nothing to solve the problem. Just because we zip users don't want to wear a watch doesn't mean we should get reduced service from Fitbit!!
09-04-2019 18:05
09-04-2019 18:05
There is an article in the list of forums stating that fitbit is aware of the problem and can't figure it out. Mine started when the app updated. If you can install the old version and turn off updates that should fix it...at least that's what the article said. However I'm not finding it in the app store. I deleted the old version, reinstalled it and it was still the updated version. The battery seems to be the only thing that can be done for me at least until I get tired of that. Good luck all!!
Best Answer09-05-2019 12:08
09-05-2019 12:08
My Fitbit app updated today and my zip is now syncing with my phone.
09-05-2019 12:09
09-05-2019 12:09
Best Answer09-05-2019 12:16
09-05-2019 12:16
Nice! Thanks for the heads-up. Just checked mine and it sync'd as well. Hopefully this lasts longer than one day. 🙂
