11-14-2018
03:12
17:16
DavideFitbit
11-14-2018
03:12
17:16
DavideFitbit
My battery died this morning and I've changed it a couple hours later. However now it shows wrong time and does not connect to Bluetooth (although the Bluetooth is on, Zip shows this warning : "turn on bluetooth to allow "fitbit" to connect to accessories") and does not sync! To sum up, nothing works properly after changing the battery! Please help
Hello @avcielif, it's good to see you visiting the Community forums for the first time, welcome.
I'm sorry to see you've been having trouble to sync your Zip device, if you haven't done so already, please try to restart your device following the steps listed here below:
If you're still having inconvenience to sync or connect the Bluetooth, you can also follow the steps in this article: Why won't my Fitbit device sync?
I hope this helps, please keep me posted.
