02-03-2016 16:40
02-03-2016 16:40
The battery died in my Zip, so I put a new one in it. When I looked at my dash board a couple of days later I noticed that none of my steps, distance, or calories were recorded. So I tried to re-sync my Zip but Fitbit Connect on my computer is not recognizing my Zip. I've already done everything suggested in the help forums...anything else I can try?
Best Answer02-03-2016 22:59
02-03-2016 22:59
Im not sure what is ment by everything.
Some steps are
Best Answer05-16-2016 07:55
05-16-2016 07:55
Hello,
This is the same problem i'v had. I took out my battery twice and it still wont regaster my steps. I dont know what a dongle is? And my coupter has been turned off and on stice this problem. Also this seems like a lot of work to do just because you had to change your battery. Is this something i'm goitn to have to do each time i have to change the battery? If so I would like a new divice. side note i have a new phone and have installed fit bit app.
Best Answer05-16-2016 10:00
05-16-2016 10:00
@cab_2_2 taking out the Battery is the way to restart the tracker, when it is not working properly, so know this should not be happening.
MY first thought is to remove the battery again, leave it out for 10 seconds, then reinstall. The last time inserting the battery might have quickly turned on/off/on the tracker.
Did the Zip turn on and properly count steps?
As for the dongle, this is the device the the computer uses to talk to and Sync the Fitbit Zip. I typed Fitbit Dongle into the search bar and found this picture of one.
As for the Sync problems what operating system is your computer running, now that you know what a dongle is, is it plugged into a USB port that you have synced through before? I would also remove the dongle, wait10 seconds, the computer should beep. Then reinsert the computer should beep again to acknowledge that something was plugged in. Then try a Sync again.
Another question, if your have Win10, is the computer a laptop?
