Welcome to the Community @mlanier. Can you tell which mobile phone are you using to sync your tracker? If you are using a Nokia Lumia 635, let me tell you that this phone is not compatible and that might be the reason why you are having problems syncing your tracker. I recommend syncing it with a computer or take a look at our list of Compatible Mobile Devices.
Happy stepping! ![]()
@mlanier Here is a help article that will help you to get your Zip synced with your home computer.
Let me know if anything else is needed my friend! ![]()
