12-12-2017
13:18
08:53
LucyAP
12-12-2017
13:18
08:53
LucyAP
I'm so beyond frustrated. syncing has always sucked but now it just won't. in the last 18 hours i've tried literally hundreds of times to get my zip to sync and it won't. sometimes i get 'device not found' sometime it gives me a bluetooth error. mostly it just does absolutely nothing. i've taken the battery out at least a dozen times. i've forced stopped it scores of times, ditto turning bluetooth off and on. i'm doing a stepbet and without syncing i'm going to be disqualified. i can't uninstall the app because it's connected to my stepbet. so, what are my options to get this to actually work?
Best Answer12-12-2017 19:37
12-15-2017 08:51
12-15-2017 08:51
Allow me to help, @tbmccall! Hey there @vagabondette! Nice to have you here! I really appreciate your feedback, this help us to keep improving our products and services.
To make sure that your tracker is working correctly, please double check if you have restarted your Zip as suggested here. Also, you can log out from your app and reboot your device. Once your device is up, log back in. If this doesn't work, please follow these tips to fix your syncing issues.
Keep me posted! 😉
Best Answer12-21-2017 06:18
12-21-2017 06:18
zip not syncing
Best Answer12-21-2017 16:10
12-21-2017 16:10
Welcome to the Forums @gladybug! Please confirm if you already followed the suggested troubleshoot from the post above. Also, let me know if you are receiving an error message when you are trying to sync.
I look forward for your reply! 😉
Best Answer12-23-2017 09:44
12-23-2017 09:44
Best Answer12-23-2017 10:26
12-23-2017 10:26
Thanks for the update @gladybug! This is odd. To better assist you I have some questions:
Also, please take a look to the help article Why won't my Fitbit device sync?
Best Answer12-23-2017 10:31
12-23-2017 10:31
Best Answer12-25-2017 08:51
12-25-2017 08:51
Thanks for posting back @gladybug! I appreciate the information provided. To further assist you, can you please confirm that you have followed the help article Why won't my Fitbit device sync? suggested on my previous post?
Keep me posted! 🙂
Best Answer12-25-2017 09:59
12-25-2017 09:59
12-25-2017 13:14
12-25-2017 13:14
So good to hear that you are back on track @gladybug! Please keep me posted if you need extra help or if you have any question.
Also, I'd like to encourage you to join us at Discussions board, there you can be inspired, find some tips to get moving, eat well, manage weight, sleep better, live mindfully and more!
Give it a look! 😉
