10-25-2017
06:38
19:31
LucyAP
10-25-2017
06:38
19:31
LucyAP
I had an update alert and completed it including changing the battery.since then it does not register any steps it just stays on 0
can you help
Moderator edit: title for clarity
Best Answer10-26-2017 19:30
10-26-2017 19:30
Welcome to the Community @JznF! This sounds odd. To make sure that your Zip is working correctly, please restart it.
Also, double check the metal spring inside the Zip's battery compartment. Sometimes your tracker will have battery issues when this is bent. You can follow this post by @vomitofthemind for extra help.
I hope this helps, keep me posted! 😉
15:23
06:35
LucyAP
10-31-2017
15:23
06:35
LucyAP
Hi Lucy,
That was a great help - thank you
Jan
Dr Janet Ferguson B.A.(Hons), Cert. Ed., MBA (Nottingham UK), PhD (Griffith)
MCIPD (UK), CAHRI
View my profile on LinkedIn
www.linkedin.com/in/dr-jan-ferguson-27157911
Moderator edit: personal information
11-06-2017 06:50
11-06-2017 06:50
@JznF You are welcome, it's always my pleasure! I'm glad to hear that you are back on track. 😉
Also, I'd like to encourage you to join us at Discussions board, there you can be inspired, find some tips to get moving, eat well, manage weight, sleep better, live mindfully and more!
Give it a look! 🙂
