05-30-2018 05:12
05-30-2018 05:12
My app states that there is an update available for my Zip. when I try to update it says can take 10 minutes however I let it go for almost an hour and it will not update. Suggestions?
Best Answer05-30-2018 18:25
05-30-2018 18:25
TammyG71, I am having the same problem...hope someone sees your post and provides some assistance!
Best Answer05-31-2018 13:23 - edited 05-31-2018 13:28
Welcome to the Forums @TammyG71 and @Gedeekay! Thanks for sharing your experience with your Zip. This is not the expected behavior.
Make sure that your Fitbit app is up to date. Then, make sure your tracker has enough battery and then try these steps:
Note that if you get notifications from your mobile device on your tracker, before you can use a different device or computer you need to follow the instructions in Why is my tracker only syncing with one mobile device?
I hope this helps, keep me posted! 😉
05-31-2018 21:03
05-31-2018 21:03
LucyFitbit...after rebooting my phone and my fitbit, uninstalling and installing, trying to update via the dongle and home PC - nothing worked. I am to the point of purchasing another fitbit and starting over...why can't the update notice just go away if I choose not to update...will it create operating issues with my fitbit if I choose not to update 😞
Best Answer06-01-2018 10:47
06-01-2018 10:47
Thanks for the update @Gedeekay! I appreciate the time and effort you have invested to solve this and I'm truly sorry for this experience.
To further assist you, I've created a Support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums.
Keep me posted if you have any other question.
06-01-2018 10:55
06-01-2018 10:55
Where would I go to find out how to sync my Zip?
Best Answer06-01-2018 13:47
06-01-2018 13:47
Welcome to the Community @pat1941! Thanks for stopping by. If your device is paired to the Fitbit app, it syncs every time you open the app. If you turn on All-Day sync it also syncs periodically throughout the day. If you sync your device with a computer and Fitbit Connect, it syncs automatically every 15 to 30 minutes when the Fitbit device and computer are nearby, and the dongle is plugged in.
To know more about how to manually sync your Fitbit device check out this article. Also, if you are having difficulties to sync make sure to read Why won't my Fitbit device sync?
06-01-2018 14:15
06-01-2018 14:15
Best Answer06-01-2018 14:54
06-01-2018 14:54
Hey there @Gedeekay! Thanks for the update! As I mention above, I created a Support case for better assist you. Just remember to keep an eye to your inbox at the email you used to register with the Community forums.
Keep me posted! 😉
01-22-2019 16:08
01-22-2019 16:08
Hello! I am having the same problem. Have tried everything.
Please advise what to do next. Thank you!
Best Answer01-22-2019 18:35
01-22-2019 18:35
How frustrating..I tried everything..uninstalling/reinstalling the fitbit app on my phone, unlink/link fitbit zip to app, tried updating from fitbit.com on laptop and THEN called the fitbit customer svc number from website. They were very helpful. My zip had gone to place of no return so they replaced it. Hope any of this is useful and best of luck
Best Answer01-22-2019 20:35
01-22-2019 20:35
So i've been living with this same issue for about 5 months. i'm glad to see you were able to resolve the issue. If i return my zip it would be my 4th fitbit device i've had to replace 😞
Best Answer01-25-2019 10:09
01-25-2019 10:09
Thank you for visiting the forums @Mnarko, @Gedeekay and @gogorichie. Welcome! I apologize for the delayed response and will be glad to assist you with your update inquiry.
@Mnarko and @gogorichie, could you please confirm that you have followed the steps that @LucyAP has shared with us.
Thank you for sharing that your Zip was replaced @Gedeekay.
Catch you later.
10-13-2019 21:58
10-13-2019 21:58
I deleted my Fitbit app and downloaded a new one - its not like the original app and will not sync my zip. So I've tried switching off my phone etc BBM but nothing works since ios13 updated. I'm not going to buy a new zip though. Not sure they're sold anymore. Always been a problem - might try Garmin.
10-14-2019 00:25
10-14-2019 00:25
Hi @JanHolm there have been some changes, with the dashboard being the one most noticed. Did you see the information about iOS 13? It's in a banner at the top of the forum pages.
