10-25-2017 17:50 - edited 03-21-2018 10:22
I've been notified that there are reports of Zip battery draining quickly on iOS version 2.41.1 and our team is currently investigating. If you are experiencing this, we recommend disabling all-day-sync for now. I'll update this post once I hear more. Thanks as always for your patience and understanding.
Turn off All-Day Sync:
Actively managing your weight? Find accountability buddies on the Manage Weight board
01-16-2018 12:56
01-16-2018 12:56
Best Answer01-16-2018 13:11
01-16-2018 13:11
Best Answer01-16-2018 16:22
01-16-2018 16:22
Best Answer01-18-2018 22:15
01-18-2018 22:15
Best Answer01-24-2018 17:18
01-24-2018 17:18
CRAZY BATTERY DRAIN! New battery on Monday, zero battery on Wednesday. I have a zip that was purchased new just a few months ago. My phone is new and my iOS is current 😞 Is anyone missing the original Fitbit and the Fitbit One? I feel like my Fitbit experiences keep getting worse, not better.
01-25-2018 02:25
01-25-2018 02:25
I hardly dare say this without touching as much wood as is possible but my zip bit seems to have behaving at least for the last couple of months which is longer than it had done for a while.and I hadn’t changed anything.
I now feel I have tempted fate !
01-25-2018 08:58
01-25-2018 08:58
add another unhappy ZIP user - my battery was replaced 3 days ago and is already dead. I walk 1 hour at 2.5 mph (treadmill) and record 0.5 miles and 1000 steps - should be 2.5 miles and 4000 steps. The only good thing about the app is tracking food/calories. Do all of the fitbit products have this problem or just the ZIP?
I see you fix to turn off all day sync - we'll see how that works.
Best Answer01-25-2018 10:34
01-25-2018 10:34
01-25-2018 10:48
01-25-2018 10:48
Best Answer01-25-2018 12:10
01-25-2018 12:10
01-25-2018 20:10
01-25-2018 20:10
Mine was better until I turned all-day sync on but I did get about 4 months out of latest battery -- 50% less than the original 6 months, but better than in the interim. I have now turned all-day sync off on the iPhone. This irks me because Fitbit continues to advertise compatibility with iOS that clearly is lacking.
Also agree with other posts that the Windows app is less than stellar.
I continue to see plenty of messages indicating problems with this and other FitBit devices and strongly suggest reading other Fitbit and other device forums before buying any new devices -- advice I have also passed along the various tech journalists who might otherwise not have the long view.
Best Answer01-26-2018 00:51
01-26-2018 00:51
Best Answer01-26-2018 04:13
01-26-2018 04:13
Glad to hear I am not alone with fast battery drain. They use to last 5 months for me and now I'm lucky to get 5 days. I love my zip but will shop around for a different brand of tracker if it is not soon fixed.
Best Answer01-26-2018 07:59
01-26-2018 07:59
Best Answer01-27-2018 17:59
01-27-2018 17:59
Any solution yet? I only get a day and a half per battery?!
Best Answer01-27-2018 18:33
01-27-2018 18:33
01-28-2018 02:14
01-28-2018 02:14
Best Answer01-28-2018 07:49
01-28-2018 07:49
well that didn't take long.
The ZIP is reporting "Battery Low" at 10:00 today - that is 24 hours for a new battery.
I did a couple more "Sync now" from the app and now the battery shows GREEN.
This my be a ZIP firmware issue falsely report a battery low condition.
I will wait till the ZIP battery dies completely.
to be continued.
Best Answer01-29-2018 07:50
01-29-2018 07:50
My Fitbit Zip used to shut off at midnight but doesn't any longer. Going through batteries like water through a sieve.
Best Answer01-29-2018 19:35
01-29-2018 19:35
my ZIP battery went dead tonight at 10:00 pm (approximate)
that is about 60 hours
a worthless piece of technology if the battery needs to be replace every 3 days (less than actually)
the Jawbone UP is still running strong
I will replace the battery in the ZIP and see if I get more than 60 hours.
again - I have turned off the background app refresh, close the app every time I use it, and turn my phone bluetooth off at night.
