10-25-2017 17:50 - edited 03-21-2018 10:22
I've been notified that there are reports of Zip battery draining quickly on iOS version 2.41.1 and our team is currently investigating. If you are experiencing this, we recommend disabling all-day-sync for now. I'll update this post once I hear more. Thanks as always for your patience and understanding.
Turn off All-Day Sync:
Actively managing your weight? Find accountability buddies on the Manage Weight board
02-21-2018 06:33
02-21-2018 06:33
I'd love to see a reply to this from Fitbit. For a while they were lasting a decent length of time. Now the battery I installed on Monday the 19th is already showing low. This is absolutely ridiculous. The only thing I did was to update the Fitbit software which obviously I shouldn't have done. I'm about done with this thing.
02-23-2018 11:07
02-23-2018 11:07
Patience!!!!! I'm now on my fourth battery this month, plus now resets any hour of the day,
Best Answer02-24-2018 11:54
02-24-2018 11:54
I have been having this problem as well. I turned off the all-day sync several months ago, but am still finding that the battery lasts only 4 weeks or so. Sometimes I get the low battery indicator for a few days, and then that just goes away and the battery keeps working for a few more weeks. Last night, my zip synced fine, with the battery indicator on the app showing “full”. This morning I am getting the low battery indicator on the zip itself and, although it isn’t still showing my steps for today, I cannot get it to sync. Is there any way to enter your step count manually in situations like this? I am part of a step challenge using the MoveSpring app, and hate to get 0 steps for today. The step count for the day is lost when you change the battery, right? (If you can’t sync beforehand)
Best Answer02-24-2018 14:03
02-24-2018 14:03
Best Answer02-25-2018 09:52
02-25-2018 09:52
I’ve been off all day sync and the batteries continue to drain rapidly. Any fix yet?
Best Answer03-02-2018 03:46
03-02-2018 03:46
Have there been any updates to this issue? I just started using mine again after a long break and I'm working on my second battery in 3 weeks.
Best Answer03-02-2018 08:57
03-02-2018 08:57
My fitbit zip battery lasts about four weeks. This is costing me a fortune. Please can you sort out this problem asap
Best Answer03-09-2018 10:46
03-09-2018 10:46
I moved from the Fitbit One to a Zip a couple of months ago now due to the battery issue.
I have gone through FOUR CV2025 batteries. The latest one was changed only on Monday and it is now Friday.
All Day Sync is off. I only tap to wake once or maybe twice a day.
I have one battery left.
after that one is deplete...in a week or so, I am done with Fitbit and may either look for another brand or forget about logging steps all together.
Fitbit has been causing me headaches for months and months.
Such a waste of my money.
Best Answer03-09-2018 11:04
03-09-2018 11:04
03-09-2018 11:07
03-09-2018 11:07
MPOW sadly only has a wrist tracker.
Best Answer03-09-2018 11:35
03-09-2018 11:35
03-09-2018 11:35
Best Answer03-09-2018 11:47
03-09-2018 11:47
03-09-2018 12:50
03-09-2018 12:50
What would removing the battery do other than make the Zip totally useless. 😳
I will contact them about this as I am getting fed up.
03-10-2018 00:54
03-10-2018 00:54
03-10-2018 09:52
03-10-2018 09:52
Today is Saturday.
A new battery was installed last Monday.
This morning, it is dead.
tossed it into the drawer.
I will be contacting FitBit.
i want my money back.
Not happy!
03-12-2018 06:31
03-12-2018 06:31
hi, I still have this problem, have had to replace battery every 6 weeks! has this issue been addressed yet?
Best Answer03-12-2018 07:21
03-12-2018 07:21
Have you tried turning off all day sync? That seems to have worked for me
Best Answer03-12-2018 08:25
03-12-2018 08:25
I am having issues with my battery draining super quickly-has anything been resolved with this issue?
03-12-2018 08:39 - edited 03-12-2018 08:41
I think most everyone here is having problems.
Everyone needs to contact Fitbit to complain.
