01-15-2018
08:32
15:09
LucyAP
01-15-2018
08:32
15:09
LucyAP
The display on my new Fitbit Zip isn't clearly showing the numbers on the right side of the screen.
Moderator edit: subject for clarit
Best Answer01-16-2018 15:13
01-16-2018 15:13
Welcome to the Forums @Derfie30! To make sure that your Zip is working correctly, please restart it. To do so, follow these steps:
Your Fitbit Zip is now restarted. You will see your tracker's version number, followed by a series of Fitbit Smilies. When you tap your tracker, it should work normally.
Keep me posted! 😉
Best Answer01-17-2018 07:34
01-17-2018 07:34
Best Answer01-18-2018 15:35 - edited 01-18-2018 15:39
Thanks for the update @Derfie30! I really appreciate that you have shared your experience with your Fitbit Zip and for all the time invested to solve this. Upon checking with Support I was able to see that currently you have a case with them about this issue. I'm sure that they can help further with this.
Keep me posted if you have any other question.
