10-26-2018 06:59
10-26-2018 06:59
My zip was working fine last night and this morning it looks like the battery died. When I check it on my phone, it's showing a full battery. Tried removing the battery and replacing...no luck. This battery is about 30-60 days old.
Best Answer10-27-2018 08:48 - edited 08-04-2025 06:39
Welcome on board @pchristakos, it's nice to see you here! Thanks for already removing the battery and replacing it, nice way to go!
That sounds more like a loose connection. Sometimes the side spring may be bent. You can ensure that the silver battery tab located in the lower right half of your tracker. I've heard other users with this issue and my recommendation is to check that the metal pin inside the battery compartment is not twisted or bent, preventing making contact with the battery. It should look like this:
On a side note, that the reason why you're still seeing a full battery on your app is because the last time you synced it has full battery and the icon updates the battery level every time you sync and since you haven't synced yet due to the tracker died so it still remains the full battery.
Hope this helps, let me know if you need further assistance!
Best Answer10-27-2018 14:07
10-27-2018 14:07
So I bought a new battery today and put it in my zip....now the app says battery is medium! The spring inside is perfectly fine.
Best Answer10-30-2018 13:01 - edited 02-06-2024 06:49
Thanks for getting back @pchristakos! Would you mind trying one more time the steps I posted above? Let me know if by doing these for a second time your app shows the correct battery level after syncing.
I'll be around, keep me in the loop!
