08-13-2019 11:48
08-13-2019 11:48
I updated the fitbit app on my iPhone just before the weekend and my zip will no longer sync with it.
I am able to sync with the dashboard on my computer.
I think there must be a bug in the updated application.
08-21-2019 12:50
08-21-2019 12:50
Finally my zip is fixed!!! Not ticked off now 😊
Best Answer08-21-2019 14:08
08-21-2019 14:08
The fix worked. Thanks everyone. What a great community!
Best Answer09-06-2019 23:08
09-06-2019 23:08
Worked for me! But are we honing to need to do that every time?! They need to fix this.
Best Answer09-07-2019 07:44
09-07-2019 07:44
Best Answer09-08-2019 10:56
09-08-2019 10:56
I would have thought that someone from Fitbit would be keeping an eye on these pages and a blog containing over 50 comments would have caught their attention. I have managed to log in and can still do so but I’m bored with having to go through taking the battery out, putting it back in and sometimes having to delete the application and download it again. I think I’ve found an answer to this problem. I’ve ordered a Garmin!
So once it has arrived it’s goodbye Fitbit.
09-08-2019 15:14
09-08-2019 15:14
04-04-2020 21:33
04-04-2020 21:33
Will zip sync with my iPhone 6?
Best Answer04-05-2020 01:53
04-05-2020 01:53
Best Answer04-05-2020 16:52
04-05-2020 16:52
Best Answer04-13-2020 22:01
04-13-2020 22:01
My Zip will Not Sync with my iMac Pro either; Tells me to turn on my Bluetooth Which is Already On. At least I can keep my readings manually from day to day. These Fit Bit Items are overpriced Crap. Most probably made in China & updating the Software is Impossible if the company won't provide the Updates OR the Process To Update..........Will NEVER BUY ANYTHING FROM THESE CROOKS AGAIN.
04-14-2020 05:08
04-14-2020 05:08
Which is why I threw mine away and now have a Garmin. So much better and no problems syncing.
04-17-2020 18:06
04-17-2020 18:06
After 3 frustrating days of trying to sinc my zip to my iPhone, I finally uninstalled my zip in my accounts. Then I reinstalled it and FINALLY I was able to get it to sinc
Best Answer05-03-2020 16:48 - edited 05-03-2020 16:50
map 71 from 14th August 2019, thank you for your comment
- just turned my phone off and followed your advice and it has worked. Not sure if laptop will work, but at least phone is, and now my Zip has the correct time too!
Best Answer05-03-2020 17:17
05-03-2020 17:17
