As a Zip user, I have the same "my Fitbit Zip has stopped synching" issue. I just experienced this problem, again, from 9pm last night until a few minutes ago. What I have found is that the battery is low even when the Zip shows it as being fully charged. There is sufficient battery charge to run the Fitbit but not enough to sync with my phone or PC. I replaced the battery with a new CR2025 and all is well (again).
I had last replaced the battery on 2/28/2019, so it was 2 months old. I tested the old battery and it registered 2.87V, which is low for a 3V battery.
Even taking the battery out and putting it back in may work for a time or two, but the problem is that the battery probably needs to be replaced.
Best AnswerI just put a new battery in about 2 weeks ago. Could the battery be bad??? After reading all the comments on the Zip I think it's probably the Zip that is bad. Fed up with Fitbit in general. I called Fitbit last week with a different problem & really did not get satisfying help. I'm done!
Best AnswerLeaving the Fitbit app running on your phone or tablet really eats up the battery quickly. I use the app every morning to sync my Zip and then immediately end the app. Also, in settings, turn off all-day sync.
Best AnswerThanks. The battery is full but it just doesn't sync. The Fitbit is 4 years old so perhaps it's had it.
Best AnswerThe Zip not syncing to your phone has nothing to do with the battery and everything to do with Android 9.0 (Pie). Your Zip will most likely still sync to a phone or tablet running an older version of android. Multiple threads about this issue on this forum.
Best AnswerUsing a fresh battery makes no difference for me. With my S10+ or OnePlus 6T, changing the battery (or simply removing and reinstalling it) does allow me to get a couple syncs, but it always stops syncing a short bit of time later.
With my S8, which is on an older version of Android, I have ZERO sync issues with the Zip; it syncs almost immediately every time that I open the app. The same goes for my PC at the office; it syncs with the Zip every time I that I open the FitBit app.
Best AnswerWell, I unpaired my Fitbit and tried to pair it again but it Fitbit is rejecting the pairing!
