07-01-2019 15:46
07-01-2019 15:46
I see others have had the same problem, my zip won't sync with my phone. (Samsung Galaxy S9)
it appears to do a random sync when im unaware but it won't do it when i try to do it.
i've tried taking the battery out but i'd have to do that every day. i've tried uninstalling and reinstalling the app and I've tried removing my device from the app then re-pairing, these all work initially but then back to square one.
not sure if its destined for the bin... so frustrating!
07-02-2019 13:11
07-02-2019 13:11
Same thing here. VERY unhappy.
Best Answer07-03-2019 13:40
07-03-2019 13:40
It appears this is a big issue that just started happening yesterday. What are they saying will it correct itself?
Best Answer07-03-2019 19:12
07-03-2019 19:12
I've had this problem for 2 months now. I have to take the battery out every day to sync my zip. I wonder if Fitbit is doing something to cause this problem since they took the Zip off the market.
07-04-2019 00:02 - edited 07-04-2019 00:03
That's an interesting suggestion Suely as i hadn't thought it could be a deliberate or 'unfixable' blip - it's though as im looking at buying a nee device as it's so frustrating.
07-04-2019 06:37
07-04-2019 06:37
They only recently took it off the market and this problem has been going on for 10+ months. It's more likely that they discontinued the Zip and stopped monitoring this forum because they couldn't figure out how to fix the syncing problem.
07-04-2019 07:03
07-04-2019 07:03
ScottAllyn
yeah mine hasn't been synching properly since about January then it will randomly sync.
I like the fitbit as it's compatible with the weight loss app i use too but obviously that hasn't been able to sync either.
Think i've decided on my next one, will still be 'fitbit' though. 🙂
Best Answer07-04-2019 07:22
07-04-2019 07:22
I was able to return it to Amazon. I hope to find one that can be a watch or clip on.
07-05-2019 15:50
07-05-2019 15:50
Same here. Hasn’t synched since July 3rd. Won’t work on iPad or Samsung.
07-09-2019 11:11
07-09-2019 11:11
Same. I have been trouble shoot 2 units, neither will sync like they are suppose too. The screen also remains on with the slightest movement.
