11-15-2017 22:09
11-15-2017 22:09
How do I set the time?
11-16-2017 00:04
11-16-2017 00:04
You can't manually set the time but it should set itself whenever it syncs to your phone or computer. It is also adjusted according to the timezone in your profile settings at https://www.fitbit.com/settings/profile
Has your fitbit been through the setup process ok and does it seem to be syncing?
11-18-2017 09:56 - edited 11-18-2017 09:58
The battery died and I did not use my Zip for a few weeks. Put in a new battery, but the time is off by about an hour and a half. Zip time shows 11:20, real time is 12:53.
How to fix this? I checked settings in Profile & it's correct, Eastern time US (If it were off just by an hour, I'd attribute it to DST; but it's off by an additional 33 minutes.)
11-19-2017 13:38
11-19-2017 13:38
Make sure the device you are syncing with (could be multiple) have that correct time.
Hope this helps 🙂
11-19-2017 18:07
11-19-2017 18:07
11-19-2017 18:16
11-19-2017 18:16
As @SteveH said, change the time zone in you’re profile here:https://www.fitbit.com/user/profile/edit
or, check out this feed to find another answer that may work for you: Solved: How can I change the time on my One? - Fitbit Community
Hope it helps 🙂
