When you have multiple fitbits connected to an account the steps from each are merged into one dashboard. It can get a bit confused if you wear them both at the same time but if you swap between the 2 and sync both trackers all their steps will be on your dashboard.
That's right. Otherwise you won't be able to see each peeson's steps, only the total of the two.
