02-23-2017
13:55
18:24
LucyAP
02-23-2017
13:55
18:24
LucyAP
I just received my FitBit Zip...after installing it, my clock is running 10 minutes slow...can't seem to locate any assistance in this matter! Can someone help?
Moderator edit: format
Nice to see you here @Lilsis26! This sound odd. What you can try is to check if your tracker is working correctly, to do so please restart it and check the inside spring. Sometimes your tracker will have battery issues when this is bent. Here is a picture of how it should look like:
I hope this helps, keep me posted! 😉
