04-01-2014 12:54 - last edited on 02-16-2019 05:17 by AndreaFitbit
April 1 2014
Planning to purchase a Google Chromebook, will Fitbit work with it?
jim
Moderator edit: format.
07-11-2015 15:14
07-11-2015 15:14
@scotty1955 Thanks for stopping by before you're going to Mexico. That's correct you won't be able to sync your Surge with your Chromebook and I'm afraid to tell you that your HTC (9) isn't a supported device so you won't be able to sync your data with this mobile device.
Fitbit trackers will save data up to 7 days of detailed information but 1 month of full information. You can check this article and get some advice.
As an alternative solution maybe you can find someone in Mexico who has a supported device and sync it every week so you won't lose your information.
Hope this helps.
07-12-2015 06:01
07-12-2015 06:01
07-12-2015 13:54
07-12-2015 13:54
07-13-2015 09:04
07-13-2015 09:04
@scotty1955 Thank you so much for the procedure that you've posted above. It seems weird to me because you don't need both devices to sync your tracker. I mean, if you have a supported device you can sync your tracker without using a computer.
Fitbit trackers will sync information to your Dashboard by using internet connection and Dongle or if you're using a mobile device, it will use internet connection and Bluetooth to sync.
07-13-2015 09:32
07-13-2015 09:32
07-13-2015 10:11
07-13-2015 10:11
@scotty1955 Thanks for the information
07-20-2015 21:29
07-20-2015 21:29
It would be really nice if FitBit would make an app to support syncing of my fitbit device. I gave up on Windows OS and strictly use my Acer Chromebook now. I had no idea that I would not be able to sync my info. Please Fitbit, you have many users and there are a lot of people getting away from Windows OS for many reasons & strictly using Chromebooks now. I would suggest it's time to make an app for us. Thanks.
07-21-2015 10:23
07-21-2015 10:23
@lisalways It's nice to see new faces around! Thanks for taking the time to share your suggestion about creating an app. I'll make sure to pass your feedback
02-15-2016 01:47 - last edited on 08-07-2021 05:08 by JuanJoFitbit
I have noticed that my Fitbit Surge can be "found" by the google chrome book, too bad it can't just sync up to the chrome book you know? Even with or without using the "Fitbit dongle."
feel free to ignore my last post, i see that people have already asked the same questions as I.
Thank you again
Leland
Moderator edit: merged reply
02-15-2016 04:39
02-15-2016 04:39
@USAAirman A warm welcome to the Community! It's so great to have you have you. As mentioned before currently it's not possible to sync your tracker directly to your Chromebook. However, you can vote for this idea because those suggestions are viewed directly by our engineers and developers and the best of this is that people can vote for them.
Thank you for your understanding
02-15-2016 09:35 - edited 02-25-2016 05:58
Why the big fuss about this? I am, and have been, a huge Chromebook user for some time. I just log into the FitBit site and look at the dashboard. I don't need to sync it, my phone, or my Nexus 7, does that.
I have no idea why you would want to sync it with the ChromeBook unless of course you have no smartphone or tablet which I don't get the impression is true from the posts I read.
03-21-2016 11:09
03-21-2016 11:09
I think that would be a good idea too, the Chromebooks do have Bluetooth.
04-08-2016 20:00
04-08-2016 20:00
Hey I fingured out a way to use the fitbit with the google chromebook
@Duckie wrote:April 1 2014
jim
How to get an accont
Go to fit.com and it should have a button that says "sign up for a free acount" and you can then just sync it so you can check your steps and everything
How to sync the fit bit flex
all u have to do is enable your bluetooth and when you enable it click on it and it should say "Flex" click on it and it with be able to
04-09-2016 04:55 - edited 04-09-2016 04:57
When you login to your fitbit account on a chromebook, I believe it only shows the data updates that have been sent via the fitbit bluetooth app on your phone. It is not updating via the chromebook bluetooth, since fitbit has thusfar refused to make their hardware and software compatible with chromebooks.
04-11-2016 10:03 - edited 04-11-2016 10:05
@jtpryan A fair question. The reason I'm interested is because my (and several of my friends') Fitbit routinely "forgets" how to synch with my iPhone 6 and Fitbit then suggests that I synch it with a computer instead. My computer is a chromebook.
06-13-2016 02:23 - last edited on 08-07-2021 05:09 by JuanJoFitbit
The need is there, I can assure you - we don't all have the additonal technology - I don't and my computer has died. I have no way to sync! very frustrating and disappointing, that's why the fuss. Also because of travelling, taking Chromebook.
i have done what you say, enabled bluetooth, Charge HR comes up but it does not sync. Disappointed.
08-07-2016 15:28
08-07-2016 15:28
Sadly there is no synch capability for Chromebook, will be interesting what FitBit will do as Android merges with Chromebook in the not too distant future.
As someone else above said, FitBit's synching with phones is extremely dodgy, and Fitbit recommends synching with laptop/desktop when synch is a problem.
I have had a FitBit of one type or another over the past four years. I have seen little to no improvement in either mobile OS, there is so much missing from the mobile apps, you are forced to go to a desktop browser. I wouldn't hold my breath for FitBit offering Chromebook support.
My wife won a FitBit recently and it had so many problems with charging which I just determined was a defective charge USB cable from the factory. A $3.00 aftermarket replacement off of Amazon fixed that problem, but she uses a Chromebook. She has an MotoX Android phone, but synching with that is as dodgy as it is with my Nexus 6. So she's given up and is offering the FitBit to the first coworker to claim it.
Looks to me that FitBit has little to no software expertise, and with our recent charge cable problem, is also falling down on the HW side too.
09-19-2016 09:06
09-19-2016 09:06
Thank God i have an IPAD i almost forgot ! whoa.. i didnt do all this hard work for nothing i need that sync !
09-22-2016 06:37
09-22-2016 06:37
Hi everyone and thank you for joining @MajicalFit. Also thank you for sharing your feedback with us @Kevin_Brown.
Thank you for your feedback about the compatibility of the Chromebook with the Fitbit trackers. As any other mobile device it require to be tested to make sure it will support all the features Fitbit offers. This has been requested by several users in our Feature Suggestions. Perhaps you are interested in share your votes and comments to make more popular this idea: Add Chromebook as a supported device.
Our product team looks forward to reading and incorporating your suggestions into future versions of Fitbit trackers and apps.
See you around and stay awesome fellows.
10-25-2016 13:28
10-25-2016 13:28
there is a way to get a Chromebook to use android apps, it is a setting and you can download google play store and download the fitbit app. i haven't tried, but i know it's possible
