09-10-2019 20:30
09-10-2019 20:30
does not sync computer says not connected to the interrnt other programs working well on the internet. how to fix this problem.
Best Answer09-12-2019 18:16
09-12-2019 18:16
I am receiving the same message. Obviously, I have internet access because I am on their site. I hope someone can help us.
Best Answer09-12-2019 23:18
09-13-2019 01:21
09-13-2019 01:21
09-13-2019 08:11
09-13-2019 08:11
@bvmss is your phone listed as compatible? Click for the list
Best Answer09-13-2019 11:03
09-13-2019 11:03
I am not connecting fit bit to my phone, using computer, program is in the computer worked fine until September 4 2019 syn stopped suddenly everything in the program works but will not syn
how to fix the problem thanks.
Best Answer09-13-2019 22:32
09-13-2019 22:32
@mesor is your computer compatible? click for the list
09-14-2019 05:52
09-14-2019 05:52
It appears that we are having the same issue. Everything worked perfectly until September 4th. There must have been a change made (update) or something. My computer has NOT lost internet connection, as the Fitbit site suggested. I don't have any trouble viewing ESPN, Facebook, YouTube, etc. Did Fitbit do something on the 4th of Sept. that would cause this issue?
Best Answer09-14-2019 06:00
09-14-2019 06:00
@mesor It appears that we are having the same issue. Everything worked perfectly until September 4th. There must have been a change made (update) or something. My computer has NOT lost internet connection, as the Fitbit site suggested. I don't have any trouble viewing ESPN, Facebook, YouTube, etc. Did Fitbit do something on the 4th of Sept. that would cause this issue?
