08-11-2019
19:33
08:58
AlvaroFitbit
08-11-2019
19:33
08:58
AlvaroFitbit
All of a sudden my Fitbit Charge 2 will not keep a charge at all! It is driving me crazy. It seems as though ever since the app was updated my Fitbit just quit.
08:59
06:03
08-12-2019
08:59
06:03
@SherBearfit, welcome! It's good that the community is growing!
Let me help you with your Charge 2 not holding a charge. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here.
Let me know how it goes.
