@EllisIngraham What you are describing sounds a lot like a known limitation of Bluetooth. If you have a Bluetooth bond between your Blaze and a mobile device (which is required for things like music control or notifications), the bond will block your tracker from syncing with a second mobile device.
If this is the case, I'd recommend the tips mentioned here. Hope this helps and welcome to the Community!
