12-25-2016 17:44
12-25-2016 17:44
The charge 2 will not remain connected to Bluetooth long enough to connect to my iPhone. I've restarted it. I've uninstalled and reinstalled the app. Turned the Bluetooth off and on and restarted the iphone. And I've tried 2 different phones. Any ideas?
Best Answer12-25-2016 17:47
12-25-2016 17:47
@Jackiethornton, I moved this to the iOS App Help Forum, where it will get more responses.
Best Answer12-25-2016 17:52
12-25-2016 17:52
Pick one of the phones you have tried, turn BY off on the others.
The phone you choose remove the tracker from the BT settings.
Restart the phone.. I don't understand the stay connected long enough.
At what step does it fail?
Best Answer12-25-2016 17:56
12-25-2016 17:56
I do only have one phone's BT turned on at a time. It fails at the step after entering the four-digit code. The connection to BT comes and goes.
Best Answer12-25-2016 18:06
12-25-2016 18:06
My charge 2 is the same. I have reset, logged out, updated software on both the phone and the teacher, uninstalled the app and downloaded again, on and on. I can't get any notifications anymore. I'm so done. Calling to see if I can get a refund tomorrow and buying an apple watch instead. It's useless to me like this.
Best Answer12-25-2016 18:39
12-25-2016 18:39
Same problem. I'm hoping a full charge will help on the fit bit.
Best Answer12-26-2016 11:39
12-26-2016 11:39
Any luck?
Best Answer12-26-2016 13:59
12-26-2016 13:59
Yes, the full charge seemed to " do something". Connected and just got me first 5000 steps badge.
