My Blaze is not recognized by the Bluetooth in my iPhone8+. I've tried to turn the Bluetooth off and on. I've "reset" the Blaze (the left and the bottom right buttons).
I've turned the Bluetooth off and on.
I've deleted the Blaze from the Fitbit app and then set it up again.
I've deleted the Fitbit app and reinstalled it.
Help?
Thanks!
Thanks for your reply.
As before deleting the device and adding it again, I’m only able to sync with my cable/case attached to my laptop. My iphone app won’t sync because it gives an error message about not being paired with Bluetooth.
I appreciate any tips you may have.
