@TexasFight I'm very happy to hear that you are part of our Fitbit family now and let me welcome you to the Community! I recommend to try the following:
1. Open the Fitbit App and log out
2. Turn off the Bluetooth and also your cellphone
3. Restart your tracker
4. Turn On your cellphone and also the Bluetooth
5. Finally, set up your tracker as a new Fitbit device
Please let me know if the issue persist, I'll be around! ![]()
If this post was helpful vote for it or accept it as a solution! Remember challenge yourself and become better than yourself. Share your story!
Hi @TexasFight, I have a second round of suggestions that should help you out. I'd recommend:
2. Rebooting your iOS device.
3. Open your iOS settings > turn off Bluetooth for 10 seconds > and then turn Bluetooth back on.
4. Use the "Replacing a Tracker.." instructions to pair your tracker to your existing account.
If for some reason the instructions above didn't help you out, you can also setup your tracker using a computer. Click here for instructions.
Even if you set up your tracker on a computer, you'll be able to sync to your iOS device. Hope this helps!
@TexasFight in addition on @DerrickS's post. Have you tried to tap your Flex rapidly for one to two seconds until it vibrates?, it will flash all five LED lights three times and show a brief spinning light pattern. The reason why I'm asking you this, is because your lights description sounds like you have the Flex on sleep mode. ![]()
Keep us posted, well be aware!
