It's nice to see you around @rmgitzlaff, I hope you're doing well. I noticed @Kmransom123 provided you an excellent recommendation for your situation; if it was helpful to you I invite you to mark the post as an accepted solution to show your support and let other members know about it. If you need further assistance, please let me know, I'll be happy to help!
Happy stepping! ![]()
@rmgitzlaff Make sure you remove the Charge 2 from your Ipad's bluetooth before trying to pair it with your Iphone. (They can only be bonded to one device at a time)
Hope that may help~
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
Hello @JOELAUDI, have a warm welcome to the Fitbit Community! ![]()
In this case I would like to suggest checking our list of compatible devices to verify if your phone is compatible with the Fitbit app first. If it is, please restart your tracker and your phone and try to set it up once again.
Give it a try and keep me posted if you need anything else! ![]()
Hello @Skyjokona, thanks for joining us, it's great to see you around. ![]()
If you have already restarted your Charge 2, I would like to suggest the following:
Give it a try and if this doesn't seem to work, my best recommendation would be contacting our Support Team. Let them know the steps you've performed so far, I'm sure they will be more than happy to get you back on track.
I hope this can be helpful, in case you need anything else feel free to reply! ![]()
Finally, thank you, the answer to my frustration at not being able to pair....'They can only be bonded to one device at a time'. Disconnected the bluetooth link to my old phone and finally, now, I can pair it with my new phone!!! 🙂
Best AnswerI finally got the Charge 2 to sync with my Iphone again. The comment that it can be paired with only one device was the key. I unpaired it with my IPad. Then restarted the Charge 2. It then paired once again with my Iphone. Thanks.
Hello @Sharris21 and @atc182, have a warm welcome to the Fitbit Community, it's great to see new faces around! ![]()
I'm glad that your issue has now been resolved. If you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted! ![]()
Best AnswerSuper,
I followed step by step instructions and my tracker and iPhone seems to be paired:-)
great
Hello @Pantarhei, thanks for joining the conversation and the Fitbit Community, it's great to have you on board! ![]()
I'm glad to hear your issue has now been resolved by following the steps in my previous post. If there's anything else I can do for you, please don't hesitate to reply, I'll be happy to help and in case you'd like to get to know more about the Community and get tips for a healthy lifestyle, I would like to recommend you to check our Discussions board where you can find many people willing to help you with your fitness and wellness goals!
Happy stepping!
Hello @Pantarhei, thanks for taking the time to reply, I hope you're having a great day. ![]()
If you haven't already done so, please check the following three GPS-related settings on your iOS device:
1. Make sure your device can track your activity when you're out of wi-fi range. To do so, tap Settings > Cellular and make sure Cellular Data is on.
2. Make sure the app can track GPS when your device is locked. To do so, tap Settings > General > Background App Refresh and make sure it's on for both the phone and Fitbit specifically.
3. Make sure your device is able to identify your location. To do so, tap Settings > Privacy > Location Services and make sure it's on for both the phone and Fitbit specifically.
I hope this can be helpful, if after checking this you're still getting the same message, please feel free to reply, I'll be happy to continue helping you. ![]()
Best AnswerHi,
The problem of pairing is solved:-)
But I'm still in the dark regarding the use of GPS on my charger.
I don't really undestand what is the procedure to activate it, because
1. If I start an exercise with my tracker and I have also my iPhone with me- ready for syncronization- on the end of exercise(walking) there is no map on my iPhone.
2. If I start an exercise on my Iphone without activating exercise with tracker, on the end there is a map on my iPhone
3. If I start an exercise both on my tracker and on my iPhone then I get a map on my iphone.
My question is, what for I need GPS on tracker if I don' see the map without acivating the exercise also on my IPhone and why the result is the same in case of procedures 2. and 3.?
Did I miss something?
Your Charge 2 has connected GPS, what this means is that in order for the tracker to trace a map when you select a GPS exercise such as walk, run or hike. Please keep in mind that all GPS devices, whether your phone or your tracker connected to your phone, require a direct path to these satellites in order to receive their radio transmissions. If the signal is being blocked—either because you're underground, near many tall buildings, or as a result of atmospheric effects—GPS will not work.
Once you select an exercise on your Charge 2, it will need to find the GPS signal first before it can start tracing a path. Check the following screens to know when your tracker has connected well:
Now, when you use only your phone and MobileRun to record your exercise, your phone is the one using its integrated GPS which means the path will be more accurate and it's harder for a phone to lose a GPS signal.
Finally, I do not recommend starting a GPS activity on your tracker and your phone at the same time because they will rewrite themselves causing data to be lost during the syncing process as 2 different devices are tracking the same activity at the same time.
I hope this resolves your inquiry, if there's anything else I can do for you, please let me know, I'll be happy to help.
Hi MarcoG,
Thanks for a prompt reply.
You are very helpfull (magician), I checked today again the screen you suggested and I've got the first time such a screen, never before appeared a phone icon in the first row.
I'll tray to use in this way the tracker later today or tomorrow morning (now is too hot- 33 degrees C:-)) and I'll let you know the findings.
Have a nice day,
Rado
Hello @Pantarhei, I hope you're having a great day, thanks for taking the time to reply and let me know your issue has now been resolved, I'm very glad.
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted! ![]()
