10-12-2017
08:43
05:57
MarcoGFitbit
10-12-2017
08:43
05:57
MarcoGFitbit
My Charge 2 keeps losing Bluetooth connection with my iPhone 7. How can I fix this?
Best AnswerThe same issue yesterday evening when I tried to update my Charge HR. (Error code 18) I solved the problem by using the windows app and connecting my HR to the laptop via Bluetooth and USB.
I hope it will work for you as well.
Hello @Skythom and @AdamBatta, thanks for joining the Fitbit Community, it's great to have you on board. It's nice to see you around too @SunsetRunner, thank you for your helpful advice. ![]()
@Skythom, please keep in mind that Fitbit trackers don't connect, sync or pair through the Bluetooth on your phone, they use the Fitbit app to do it. If after trying @AdamBatta and @SunsetRunner's suggestions you're still having trouble, my best recommendation would be setting up your tracker as a new device to reset the connection between your tracker and your phone. Don't worry, none of the information already stored in your account will be deleted.
To set up your tracker as a new device:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
