11-21-2016 10:30
11-21-2016 10:30
11-22-2016 04:10
11-22-2016 04:10
Hello @oneputt66, welcome to the Community! ![]()
Is the issue related exclusively to notifications? If so, I'd like to recommend going to the Bluetooth settings on your phone and check if Charge 2 is on the list of paired devices, if it is, tap on it and select Forget this Device. After that, restart your mobile device and follow @ErickFitbit's helpful instructions to setup notifications on your device to reset the pairing.
In case your tracker is not syncing correctly, as you have already tried several troubleshooting steps, try to setup your tracker as a new device:
To set it up:
Give it a try and let me know if you need anything else! ![]()
03-14-2017 08:00
03-14-2017 08:00
I must do this every week in order to get my Fitbit to sync with my iPhone 7. Frustrating! I never had this issue with my Fitbit Charge
Best Answer03-16-2017 09:49
03-16-2017 09:49
Hello @Ricster1963, thanks for joining us, it's great to have you on board!
Have you tried to restart your tracker lately? Do you have All-day Sync enabled in the Fitbit app? If so, I would like to suggest force-closing the app by double tapping the home button on your phone and swiping up the app. If that doesn't do the trick, please log out from the app, restart your phone and log back in, this will refresh the information and force your tracker to sync.
I hope this can be helpful, give it a try and in case you need anything else feel free to reply, I'll be happy to continue helping you.
