06-09-2020
13:22
09:44
AlejandraFitbit
06-09-2020
13:22
09:44
AlejandraFitbit
For the past three days, when I would start a ride or walk using the app on my iPhone, I would bike 22 miles and the GPS stops within minutes of starting. I have experienced this since this past Saturday. I have tried deleting the app and reinstalling it, but that hasn't helped. Just wanting to know if anyone else is experiencing this?
Best Answer@ColdWarVet75 What type of phone do you use? Android or iOS? You are describing an app issue, not a Charge 4 issue. You might get more help in the appropriate app forum. BTW, the app was never designed for biking. It is for three step based activities -- run/walk/hike. You also just spent a bunch of money for a device that has built in GPS with an exercise app and a bike shortcut. Any reason you aren't using it?
Laurie | Maryland
Best AnswerHello @ColdWarVet75 I've moved your ios question out of the Charge 4 board.
Yes any gps is going to use a lot of power your trying to time how long it takes a signal, from at least 4satellites to travel from space to you then do this several times a second. So yes the decision is to choose the tracker or phone for a dead battery. Fitbit suggests charging after each gps use.
09:46
09:41
06-22-2020
09:46
09:41
It's great to see you here, @ColdWarVet75. @LZeeW and @Rich_Laue, thanks for the input.
As our friends here mentioned, Charge 4 has built in GPS. I recommend using that feature instead of the app. Also, keep in mind that GPS dropouts can be caused by several things (tall buildings, trees, overcast, etc.).
For more information, check the article: How do I use GPS on my Fitbit device?.
Let me know the outcome. 🙂
