02-27-2016 02:43
02-27-2016 02:43
02-28-2016 07:58
02-28-2016 07:58
@Lovemyexercise Welcome to the Fitbit Community! Is it giving you any instructions to follow when it "finds" the tracker? Follow these replacement set up steps to connect your new Charge to your account. It should work properly after following them.
Let me know how it goes!
02-26-2017 12:52
02-26-2017 12:52
New Fitbit will not add says already added
02-27-2017 08:48
02-27-2017 08:48
@Pineisland3 Welcome to the Fitbit family! Is it the same tracker than the one you used to have? If it is, it will tell you that it exists but if you want to "replace" it. You need to replace it to continue the set up process for the new one.
Now, if it is a different type of tracker, you will need to select it accordingly and no message will pop-up. It will just let you set it up accordingly.
What tracker are you trying to set up?
Keep me posted!
