06-02-2022 18:47 - edited 06-02-2022 20:06
Is there a way to change the volumes of the “quick add” buttons in the water tracker on the app? They’re currently set to 8oz, 16oz, and 24oz… I’d like to set them to sizes that match the vessels I regularly use.
I did a search and apparently this has been “released” but I can’t find the option anywhere.
06-05-2022 16:42
06-05-2022 16:42
Welcome to the Fitbit Community, @sparklingsights.
Thank you for your question.
Currently, there is no option to customize quick add water sizes on the Fitbit app. The released feature you mentioned refers to some apps on the Fitbit App Gallery that can be installed on devices like Fitbit Sense or Fitbit Versa and allow users to customize the quick add buttons on the Watch.
There is a feature suggestion called "Customize “Quick Add” tiles inside ‘Water’ tab on Today screen". You are welcome to vote it and if there is any update, it should be communicated as soon as possible.
Have a nice day.
Best Answer06-05-2022 16:42
06-05-2022 16:42
Have a nice day.
Best Answer06-05-2022 16:44
06-05-2022 16:44
Thanks! With only 87 upvotes in the past 3 years on that topic I guess I won’t hold my breath for that feature. Appreciate the response, though.
06-04-2023 01:33
06-04-2023 01:33
That's a shame. We've been asking for this ability for years. Unless your usual containers match ones of the sizes, which none of mine over years and years have, the buttons are useless. They never get used because they are wrong, we can't change them, and we can't remove them, meaning they are just useless screen clutter.
06-08-2023 17:49
06-08-2023 17:49
Hi there, @MikeRK.
Thanks for joining this thread and sharing your thoughts about this situation. I'm sorry for any inconvenience this has caused and if you haven't done so, make sure to vote for that suggestion as that's the best way to get the attention of our developers.
Once again, I appreciate your feedback and please know we'll keep working to improve our devices, as well as services.
