08-06-2018
23:03
05:34
MarcoGFitbit
08-06-2018
23:03
05:34
MarcoGFitbit
Can't get my Fitbit to Bluetooth to my phone
I would try restarting your phone and then restarting your fitbit using this procedure:
https://help.fitbit.com/articles/en_US/Help_article/1186/
Give this a few tries as it doesn't always work. You might also try forgetting the fitbit in your phone's bluetooth settings. If it still won't sync after that then there are some more ideas to try in this help file:
Hello @Sherripout, thanks for joining the Fitbit Community, it's great to have you on board. I appreciate your help @SteveH, it's always nice to see you around. ![]()
@Sherripout, I appreciate you have brought this to my attention. Tell me, which tracker are you currently using? Have you restarted it yet as @SteveH mentioned? Are you having trouble setting it up or syncing it?
If you're having trouble setting it up, please follow these steps:
On the other hand, if you're having trouble syncing, please check these steps:
If your device still won't sync, try these steps:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
