10-01-2016 17:30
10-01-2016 17:30
10-04-2016 06:18
10-04-2016 06:18
Hi @Latteda70, welcome aboard to our Community. Usually we do not recommend to uninstalled the app since this may provoke to loose information. This troubleshoot only apply in specific scenarios.
By the description you provided, I recommend to make sure your tracker is pair on your account. When your tracker is not pair, many of the activity tiles will not be visible. If this is the case, try to set up your tracker again doing the following:
Hope this helps. See you around and keep me posted how it goes.
10-04-2016 06:18
10-04-2016 06:18
10-04-2016 07:11
10-04-2016 07:11
