02-11-2016 08:12
02-11-2016 08:12
When I scan a food and I hit save on my I phone 6 the screen is locked and wont go back I have to turn the phone off and back on to enter another food
Best Answer02-12-2016 04:55
02-12-2016 05:10
02-12-2016 05:10
Moved this thread from the One to the iOS section since being more relevant to the topic.
Wishing a wonderful day / weekend.
Best Answer02-12-2016 13:06
02-12-2016 13:06
Best Answer02-14-2016 09:57
02-14-2016 09:57
@wadewi I'd recommend double checking your iOS settings to make sure that you've given the Fitbit App permission to use your camera. Next, I'd recommend reading our Food Scanning FAQ for more information about how food scanning works.
Hope this helps you out and keep me posted if you have any additional questions.
Best Answer02-14-2016 12:48
02-14-2016 12:48
Best Answer02-14-2016 14:47
02-14-2016 14:47
@wadewi Thanks for the quick followup. I would recommend the following steps:
1. Reboot your iOS device.
2. Log out and then log back in to the Fitbit App.
3. Experiment with closing background apps while food scanning. You can force close by: rapidly double tapping your iOS home button > swipe left until you see a preview of the App that you want to close > and swipe up on the preview.
4. Also double check to make sure that you are connected to the internet either through WiFi or Mobile Data.
Keep me posted if this helps you out!
