10-09-2018
17:48
05:10
MarcoGFitbit
10-09-2018
17:48
05:10
MarcoGFitbit
Major issue connecting new iPhone to Charge 3.
Bluetooth doesn’t connect.
All the links with what to do are worthless.
No problem with other Fitbits.
So far Charge 3 is a bust
10-10-2018 05:12
10-10-2018 05:12
Hello @DorranceS, thanks for joining the Fitbit Community, it's great to have you on board.
I appreciate your participation in the Forums and for sharing your experience with us. Please note that your Charge 3 does not connect directly through the Bluetooth Settings on your phone but through the Fitbit app. At this moment I would like to gather some information from you so I can check this further:
Thanks for your patience and understanding, I'll be waiting to hear from you.
10-10-2018 06:19
10-10-2018 06:19
10-10-2018 07:01
10-10-2018 07:01
I’m having the same issue. It can’t connect to the iPhoneX. It did when I first set it up but not after since. I’ve tried everything as well and nothing seems to work.
10-10-2018 07:35
10-10-2018 07:35
10-10-2018 07:58
10-10-2018 07:58
It’s a lot of money down the tube. I had it working for one day then it disconnected and won’t sync again
10-10-2018 08:07
10-10-2018 08:07
10-11-2018 06:42
10-11-2018 06:42
Hey guys !! So I called Fitbit. I had to reset or reboot the fit bit and turn off the phone for 19 seconds then turn it back on and set it up again. The info of calories,sleep,steps won’t be lost but your weather settings and alarms will.
No reboot/restar press the side botton on the Fitbit for 8 seconds until a happy face appears in the screen.
Mine is working perfectly since.
10-11-2018 06:51
10-11-2018 06:51
Well I posted what works but they are deleting the posts.
You have to restart the Fitbit.
Basically, attach the power cord then hold the button down for 8 seconds.
It still seems to be an issue they need to fix, but restarting it seems to be a temporary fix.
10-11-2018 07:33
10-11-2018 07:33
10-11-2018 07:56
10-11-2018 07:56
Hello everyone, I hope you're doing well.
I appreciate you have reported this to us and shared your experience with the Charge 3. At this moment, as @Stratty33 and @SunsetRunner mentioned, please restart your Charge 3 following these steps:
After that, try to sync or set up your Charge 3. If you're setting it up, please plug it in and make sure it's charging. Give these steps a try and let me know the outcome!
10-16-2018 10:42
10-16-2018 10:42
Returning the Fitbit charge 3 now. Never again.
10-24-2018 02:21
10-24-2018 02:21
Same here. iPhone X.
Waited 3 weeks just to get this non functioning band.
Seems to to be a wide spread issue upon googling.
I didn’t find users that managed to solve this..
only buy buy replacing the faulty device.
Shameful.
10-24-2018 05:56
10-24-2018 05:56
10-25-2018 09:08
10-25-2018 09:08
I appreciate your participation in the Forums and for letting us know you're still experiencing these issues related to your Charge 3 not syncing. At this moment I would like to gather some information from you so we can determine what we should do next.
If you have already contacted our Support Team, my best recommendation is to keep working with them as they will have more options to share with you. For those who haven't contacted our Support Team, I'll be waiting to hear form you.
Thanks for your patience and understanding, I hope you have a great day.
10-25-2018 09:46
10-25-2018 09:46
I’ve successfully returned the fit bit charge 3. Never again. Too many issues. It seemed, honestly like no one care and the product was rushed out to customers.
10-30-2018 10:13
10-30-2018 10:13
Hello @SunsetRunner, I hope you're doing well, thanks for taking the time to reply.
I appreciate you have come back and keep me updated about this situation. I sincerely apologize for the inconveniences this issue has caused you. I appreciate the feedback you've provided and will make sure to pass it along to our team.
Thanks again for participating in the Forums, I hope you have a great day.
12-03-2018 12:37
12-03-2018 12:37
Same issues. And I really dislike the choice of screen layouts. Hate to leave Fitbit, but it may be time.
12-04-2018 06:52
12-04-2018 06:52
Hello @Looseleaf, I hope you're doing well, have a warm welcome to the Fitbit Community.
I appreciate your participation in the Forums and for sharing your experience and feedback with us. I sincerely apologize for the inconveniences you've come across so far. Could you please elaborate a bit more about the issues you're experiencing? Additionally, I would like to get some information from you so we can check this issue further:
Thanks for your patience and understanding, we'll be waiting for your reply.
01-07-2019 21:38
01-07-2019 21:38
iPhone X
Charge 3
12.1.2
I can’t get the device version, but the version of the charge 3 was up to date as of Dec 25th - when I tried to do the update it asked me to do a couple of days after that. It would not update - tried 3 times. I restarted both devices, deleted the Charge 3, and deleted the app. Reinstalled the app, and it gets as far as showing the activation code on my Charge 3. The next step timed out 4 times to the end of an X in a circle on the Charge 3.
Ashley
