10-05-2017
23:52
06:41
MarcoGFitbit
10-05-2017
23:52
06:41
MarcoGFitbit
I'm using my iPhone to count steps and syncing with the Fitbit app which is working well. I have a problem when cycling as the iPhone records steps which are then synced to the app. My cycle ride data is synced from Strava to the fitbit app and correctly appears as an activity. This means that I have excess steps during the cycle ride which need to be removed.
I have tried adding a driving activity for the duration of the cycle ride and this zeroes the steps, but it also removes the calories used from the cycle ride, so this is not a solution.
I have also removed the steps from the IOS health data for the duration of the cycle ride and re-synced with the fitbit app expecting the steps to be removed from the fitbit app, but unfortunately the fitbit app is not removing the steps which have been removed from the IOS health data. This would be the best solution for me, but it looks like the fitbit sync does not re-sync for the period of time that has already been uploaded and so the deleted steps are not removed from the fitbit.
Is there any way that I can remove the excess steps from the fitbit app, whilst retaining the cycle activity and the calories burnt during the activity?
Thanks
Best Answer10-07-2017 06:52
10-07-2017 06:52
Hello @Slowcoach, have a warm welcome to the Fitbit Community, it's great to have you on board. ![]()
This seems like a very odd situation, usually when an activity is recorded in the app, this activity rewrites the data and the steps measured by MobileTrack get replaced by the steps from the activity.
Nevertheless, my best recommendation would be removing MobileTrack from your account and set it up again to reset it:
Then, record a new activity and check if the steps get replaced or duplicated.
I hope this can be helpful, give it a try and keep me posted in case you need anything else. ![]()
Best Answer10-08-2017 07:25
10-08-2017 07:25
Best Answer10-09-2017 06:38
10-09-2017 06:38
Hello @Slowcoach, I hope you're doing well, thanks for taking the time to reply. ![]()
I appreciate you have tried the troubleshooting steps I provided earlier, at this moment I'll forward your information to our team so they can take a better look at this. Once I have more information to share with you about this issue I'll make sure to update the thread accordingly.
Thanks for your patience and understanding, in the meantime, if there's anything else I can do for you, please feel free to reply.
