The only thing that is registering is calories used. I cannot get access to sleep, steps, or any other feature. I have reset the device, but it didn’t make any difference. In desperation I removed the device from my phone and then tried to register it again. Unfortunately my phone could not find the device. Has my device just stopped working? Has anyone else experienced this?
Syncing / connection problems, unfortunately, happen from time to time, often for no apparent reason.
The usual things to try are:
These have always worked for me when I’ve had problems but others have found other steps that worked for them. For example:
If none of those ideas work for you then it’s probably best to contact customer support via: contact.fitbit.com
Hi
thanks for your interest. I’ve tried all of the usual ways to address this, but nothing worked.
It it has now moved on. I contacted customer support, and when I didn’t hear from them, I checked my trash box. There I found a message from a couple of weeks ago asking whether I objected to a change of email address. I’d obviously had the account hacked. Since then I’ve contacted customer support several times, and apart from the computer generated replies, I haven’t heard anything from them. It looks as though I’ll end up having to close the account. I’m really disappointed with Fitbit’s handling of this situation.
I hope this this may serve as a warning to others. Check your Trash box regularly as a matter of course.
Carol
