10-26-2016 15:27 - edited 03-05-2017 12:17
Fitbit Update 3/3/17
This issue should be released with the release of Fitbit iOS App version 2.33. Click here to be redirected to the iOS App Store to update.
Fitbit Update 10/26
Some users are reporting that the heart rate graph on the iOS App is not loading even post sync, this is a known issue that our team is actively working to fix.
Force quitting and reopening the App has been a successful workaround for a lot of iOS users experiencing this issue on the Community, and I would recommend it until a long-term fix is implemented.
Since this is an App-related issue, you should also be able to see your heart rate on your Fitbit.com dashboard as well.
10-05-2016 16:20
10-05-2016 16:20
10-06-2016 10:18
10-06-2016 10:18
10-07-2016 06:37
10-07-2016 06:37
10-07-2016 17:39
10-07-2016 17:39
Me too. Just got my HR. I have to reinstall the app to get it to sync but its going to the website just fine
10-10-2016 23:13
10-10-2016 23:13
I am having the same issue with my new Charge HR 2, syncing to the app on an iPhone 6. Both the Fitbit and the iPhone are running the very latest versions of their respective softwares. I found force-quitting the Fitbit app and reopening it did fully sync the heart rate, but only sometimes. Looks like a sync bug.
10-11-2016 06:25
10-11-2016 06:25
Restarting the app on my iPhone did the trick for me as well. The missing chart data from yesterday now appears.
10-13-2016 05:38
10-13-2016 05:38
The last app update didnt fix the problem.
10-13-2016 05:48
10-13-2016 05:48
10-13-2016 05:52
10-13-2016 05:52
10-14-2016 23:20
10-14-2016 23:20
10-17-2016 14:55
10-17-2016 14:55
10-17-2016 15:43
10-17-2016 15:43
Hi everybody,
This is a known issue with the iOS App that our team is currently working to resolve.
In the meantime, force quitting and reopening the App has been a successful workaround for a lot of iOS users in the Community.
10-17-2016 23:15 - edited 10-18-2016 07:05
Hey everyone,
the recent updates (app 2.28 and fitbit 22.44.12) solved the problem for me under iOS 10!
There is no background synchronization though.... but now my fitbit doesn’t interfere with my Bluetooth free speaking system anymore – so for me it is a win win.
Edit:
cheered too soon... it did not solve the problem... **ahem** it...
10-18-2016 18:38
10-18-2016 18:38
10-25-2016 06:53
10-25-2016 06:53
Hi there @GnortenJones, @Kerryf78, @Monkey121, @fenchurch1, @tarkoid and welcome aboard to our Community @DrLou and @Valerie71.
Thank you for bring this issue to our attention and I'm sorry all of you are experiencing this problem regarding the heart rate is not updating. I've seen in some users, this issue is corrected by force quiting the app:
1. Double tap the home button on your iOS device. Your open apps will show on your device's screen.
2. Close the Fitbit app by swiping the app image in an upward motion.
3. Reopen the Fitbit app.
Although as most of you have mentioned before, the issue despite is corrected, after a time keep persisting. This is a glitch provoked with the update of the iOS 10. Our team has released some updates for the Fitbit app to address different bugs and as you may know the latest version for the Fitbit app on iOS is 2.28; however this issue with the heart rate still persists with some users. So I will pass your feedback and rest assure our team is working hard to fix this as soon as possible.
Thank you for your patience and see you around.
10-25-2016 07:07
10-25-2016 07:07
11-06-2016 10:49
11-06-2016 10:49
11-12-2016 12:48
11-12-2016 12:48
11-23-2016 10:08
11-23-2016 10:08
Still not fixed with version 2.29 update. Not really good enough.
11-26-2016 17:46 - edited 04-06-2017 06:57
Same here! When will you solve it?
Usually all stores have a large number of discount codes. The hard part is that you can't separate the new ones from the old. To solve this problem I started to browse through vouchers4u.com every day, because they always publish the new codes as they get them.
