10-26-2016 15:27 - edited 03-05-2017 12:17
Fitbit Update 3/3/17
This issue should be released with the release of Fitbit iOS App version 2.33. Click here to be redirected to the iOS App Store to update.
Fitbit Update 10/26
Some users are reporting that the heart rate graph on the iOS App is not loading even post sync, this is a known issue that our team is actively working to fix.
Force quitting and reopening the App has been a successful workaround for a lot of iOS users experiencing this issue on the Community, and I would recommend it until a long-term fix is implemented.
Since this is an App-related issue, you should also be able to see your heart rate on your Fitbit.com dashboard as well.
12-09-2016 00:47
12-09-2016 00:47
New update of the iOS app today and the bug is still not fixed. 😞
12-09-2016 03:30 - edited 12-10-2016 11:00
Yup same here
how difficult can it be ... force graph update after sync ....
this has been reported dozens of times for months now .... come on fitbit !
12-09-2016 10:32 - edited 12-09-2016 10:33
Latest update didn't fix the heart rate graph issue for me, either. It has gotten beyond a joke that it has not yet been fixed.
12-14-2016 20:27
12-14-2016 20:27
force the closing of the ISO app worked for me. Thank you
12-15-2016 06:03
12-15-2016 06:03
Hi, has this issue been fixed in the last iOS app update? Heart rate graph still only updating after app restart? Thanks!
12-15-2016 06:20
12-15-2016 06:20
12-15-2016 06:20
12-15-2016 06:20
Restart 😩
12-16-2016 22:34
12-16-2016 22:34
Is this issue truly being worked? It's been a while and the issue is definitely quite annoying.
12-18-2016 08:00
12-18-2016 08:00
So when are you going to fix this problem? It is now December and this message is from October. I have a Blaze and a Charge HR and both were syncing heart rate fine until I updated to IOS 10.2.
12-19-2016 09:18
12-19-2016 09:18
Are you suggesting deleting the app, then reinstalling it? This issue is happening to my wife's Charge 2, and my Blaze. I've read that there is an issue with IOS version 10.2 causing the sync feature to stop mid flight, so to speak. I haven't updated that as yet untill we get an all clear from Fitbit. So far, the only way I have been able to update the heart rate gragh on my app is to reset my iPhone. Bit of a nuisance for sure. I hope they come up with a solution soon.
12-19-2016 10:38
12-19-2016 10:38
Double click and swipe up to quit the app is sufficient for me, with no need for a full reset. It sure is annoying to have to do it a few times a day though.
12-20-2016 08:34
12-20-2016 08:34
12-20-2016 10:09
12-20-2016 10:09
You may need to restart the app a couple of times before the heart rate data shows on the graph. The data is there, the line just isn't showing.
12-20-2016 22:45
12-20-2016 22:45
This refers to a Charge HR with a 5S iphone. iOS on the phone and the fitbit app are current as of 12/20/16. The heart rate display sync issue in the app is unresolved for me. The correct display is still present on the fitbit.com dashboard, so the HR is recording/syncing data.
Things which do not resolve this problem are:
1) quitting and restarting the app
2) resetting/ restarting the Charge HR
Two things which do work, on a one-time only basis are:
1) a hard restart of the phone
2) deleting and re-installing the fitbit app
Of the two, the first work-around is less annoying. So, no data loss, but some annoyance.
-wjb
12-22-2016 19:24 - edited 12-22-2016 19:26
wow I have this exact same issue and was encouraged to see someone had already started a thread about it....but very discouraged to see the thread was started in SEPTEMBER and it's now almost the new year and the issue has not yet been fixed. Hopefully sometime soon 😕
12-25-2016 19:54
12-25-2016 19:54
i
I bought fitbit charge 2 yesterday. I can see that the heart rate chart is not updating unless i switch off and on my iphone.
Can i know if the application bug been fixed ?
Thanks
12-26-2016 00:46
12-26-2016 00:46
It hasn't been fixed yet. Apparently it's on Fitbit's list of things to do.
12-26-2016 07:32
12-26-2016 07:32
12-26-2016 07:33
12-26-2016 07:33
12-26-2016 08:29
12-26-2016 08:29
This is an update on a previous post. To recap, it's for current iOS and Fitbit software on an iPhone or iPad pro and assumes that heart rates are recorded, uploaded, but improperly displayed. The following corrects the problem, but doesn't solve the bug.
1) Exit from the Fitbit app
2) Go to Settings--> Fitbit on the phone or iPad
3) Toggle "something " (Media Library, Background App Refresh, etc.) on or off. It doesn't matter which and it doesn't matter if you toggle them on or off. Get out of Settings.
4) Relaunch the Fitbit app.
5) Do a manual Sync either by dragging down the setup screen or going to the setup screnn. I usually do the latter. The automatic sync doesn't work every time.
This displays the plot of heart rate vs. time up until that point. It's a workaround because the problem returns immediately; i.e. go away for 10 minutes and the display isn't up to date again.
-wjb
