09-17-2018
10:27
08:26
MarcoGFitbit
09-17-2018
10:27
08:26
MarcoGFitbit
Hi. Woke up today Battery dead . Recharged for 2 HRs seemed to be fully charged. On walk I noticed Screen was dead. When I returned I recharged. App said full charged after approx 30 mins but screen was showing 10.57.47 time Charge 2 died on walk. I cannot get it to come back on again. I looked up Help articles & it suggested deleting device & turning off Bluetooth on iPhone 7 & then back on again . App says it s sending 4 digit code but Fitbit is still locked on last time as above & therefore I cannot see Code ! Help
Moderator Edit: Clarified Subject + Format.
Best AnswerHi @Savage1959. In this case, I would suggest you restart your Charge 2. Do it a couple times, making sure your tracker vibrates and you see a battery icon on your tracker’s display each time. Tap here for instructions.
By the way, when you attach your device to the charging cable to charge, you should also make sure you feel the vibration and see the battery icon. That is how you know it is attached correctly.
Hope this helps! Please let us know.
Hello @Savage1959, thanks for joining the Fitbit Community, it's great to have you on board. It's nice to see you too @SunsetRunner, thanks for all your help. ![]()
I appreciate your participation in the Forums and for sharing your experience with us. Thanks for letting me know about the troubleshooting steps you've tried so far. If you have already tried to restart your Charge 2 as @SunsetRunner mentioned, please try the following steps as well:
I hope this can be helpful, if there's anything else I can do for you, please feel free to reply.
