01-03-2020 16:33
01-03-2020 16:33
I accidentally deleted where I log my water. How do I restore that feature? Can’t find it in settings TYIA
Best Answer01-03-2020 16:44
01-03-2020 16:44
Hello and welcome to the Fitbit Community @Dau66
Sounds like your water tile got deleted by accident. No worries 😃
open your Fitbit App
tap the word “Discover” on the bottom left corner of your screen
Now scroll down and tap “Health & Fitnesses Stats”
Here you will find tiles that can be monitored and activated
Each item that you want monitored you need to ensure a green check mark is on that tile
if a green check is missing that you want just tap that tile then scroll down and tap “Add to Today”
** Doing this will now pop you back to the main page of the Fitbit App. Look through your completed/current challenges and you should see the new tile you activated. Once you find it tap that particular tile to see more information.
If you want to add more tiles then repeat the steps above and pick another one you want to add as well. Once you add all the tiles you desire you can edit how they look on your main page by following these steps:
tap the word “edit” located just under the message envelope
you can press and hold each item using the three horizontal lines to the right and drag it up or down
once your satisfied with the placement tap “save” on the upper right
sync your device to activate the changes.
😃 Please let me know if this answers your question. If this does indeed answer your question could you please tap the “choose as best answer” box just under my post? Doing so really helps other individuals who come to this community looking for answers to questions similar to your own. I’d really appreciate it!
