03-24-2024 06:32
03-24-2024 06:32
I use an Inspire HR with my Android phone to track my walking exercises. I am finding that the tracker takes a while to connect to my phone, asking me each time to start the app first ( it didn't use to do this) The App. is also loosing the positioning on the route, it will be tracking accurately and then it will stop tracking position ultimately getting its position again and carrying on.
This is not a loss of GPS signal because today I did a test using Fitbit/Inspire HR and Wahoo/Garmin HR strap at the same time on the same phone. The Wahoo App did not loose its position.
03-25-2024 11:01
03-25-2024 11:01
@RoboCop-UK , Nice to see you again. Thank you for your message.
Depending on your phone, you might have 1 GPS connection available at a time. If you are using 2 apps with GPS, your phone might only connect one.
That being said, it seems that your Fitbit app is not allowed to run in the background. This makes that the GPS gets disconnected when the app is not active or the display of your phone is off.
I'd suggest you to have a look at the following
03-26-2024 02:57
03-26-2024 02:57
03-28-2024 08:00
03-28-2024 08:00
I have tried what you suggested. item 2 link is for iOS not Android but I did find another post 9shown below) which i did try as well
Make sure that your Fitbit app is up-to-date (iOS, Android)
Neither has made a difference. I find that the Inspire HR does not want to link to the Fitbit App. It tries and then asks for the Fitbit App to be started. Even with the phone beside the tracker, and with the app started, it does connect.
It records the activity ok, and uploads it to the internet, but I can no longer use the phone for tracking the GPS as it doesn't connect.
Has there been an update that might have caused this?
03-28-2024 09:44
03-28-2024 09:44
@RoboCop-UK , Thank you for your reply and sharing the steps you tried.
Just to confirm. Do you start the activity on the tracker and need Connected GPS to track your map, or do you start the activity on the Fitbit app?
This will help me identify if there is an issue with Connected GPS or MobileRun ( option in the app where you can only select, run, hike and walk) .
03-28-2024 12:54
03-28-2024 12:54
I start the activity on the tracker by selecting 'exercise/walk/ and the icon flashes as it use to only now it stops and says 'not found' and then says 'launch fitbit app'
Some time back I used to use the MobileRun feature for walking but I when wanted to select 'Bike' I found you couldn't and that is when the Community explained the new way was to start the tracking from the tracker not the phone.
03-28-2024 13:07
03-28-2024 13:07
@RoboCop-UK , Thank you for your reply and further information.
Our team knows about an issue with Connected GPS and are working on a solution for it. I apologize for the inconvenience that this might have caused.
We appreciate your patience until this gets solved.
I'll update the thread, should I receive more information about this.
In the meantime, make sure to have the latest Fitbit app installed.
04-07-2024 04:28
04-07-2024 04:28
What is happening with this problem?
You can see that it is still not tracking. This used to be a working feature why has it stopped?
It isn't my phone at fault so is it the tracker or the app.?
04-09-2024 15:08
04-09-2024 15:08
@RoboCop-UK , Thank you for your reply and the screenshot.
As already mentioned on my previous post our team knows about an issue with Connected GPS and are working on a solution for it. I apologize for the inconvenience that this might have caused.
05-06-2024 19:29 - edited 05-06-2024 19:33
Hello,
Looking for an update on the GPS tracking issue on fitbit inspire hr. There has been no update in over a month to resolve this issue. I have utilized all troubleshooting suggestions and my gps still shows Im walking through a lake. When the gps is not tracking properly, it impacts pace and total mileage which will determine overall calorie burn. When will this get resolved?
05-07-2024 10:19
05-07-2024 10:19
@Jhess97 , Nice to see you around. Thank you for the screenshot and your feedback.
Our team is investigating this and working on a solution. We haven't received an ETA yet, but believe me, this is one of their priorities at this moment.
In the meantime please keep an eye open for any Fitbit app update available.
Try to keep the app updated, as a solution might come with the update before we are able to post it here.
05-08-2024 10:49
05-08-2024 10:49
This has been going on too long. It used to work then suddenly it dosen't.
Makes me think it's intentional; we will have to upgrade to trackers with GPS.
