12-25-2019
06:55
09:16
AlejandraFitbit
12-25-2019
06:55
09:16
AlejandraFitbit
We purchased 2 Ace 2 for our daughters. One we set up without issue and the other will not turn on. App shows it as being 100% charged as it's been plugged in for hours.
Moderator edit: content
12-26-2019 09:17
12-26-2019 09:17
A warm welcome to the Community, @Janesmom.
I appreciate your preference to our products. If one of the units isn't turning on, I recommend restarting it by doing the following:
Let me know how it goes. 🙂
Best Answer12-27-2019 03:51
12-27-2019 03:51
Hi similar problem.
I try to restart by instructions. Sometimes I can see smile face, but no vibrations. A I can see ace by Bluetooth, but cannot pair.
Any advice?
Best Answer12-27-2019 09:37
12-27-2019 09:37
I am having the same problem holding for 5 seconds can see the smiley face but no vibrate. It seems to be picking up the steps on the app but no display at all on the watch itself?
Best Answer12-30-2019 07:38
12-30-2019 07:38
Hey guys, thanks for your participation in the Forums and for the efforts in trying to fix this display issue.
@Janesmom, upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
@Delt900, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
In the meantime, let me know if you need anything else. 😉
