12-16-2024 15:32
12-16-2024 15:32
I have a Fit bit Ace 3 for both of my sons. The one screen is a lot dimmer than the other. I’ve turned the dim screen to OFF and have also restarted the watch with the same problem.
12-17-2024 08:49
12-17-2024 08:49
Welcome to the Fitbit Community, @Darrelmayn. I'm sorry to hear that your kid's Ace 3 screen is too dim and thank you for letting us know about the troubleshooting steps you have followed. I'll be happy to assist.
Please make sure that the device is not on do not disturb or sleep mode and confirm that you have followed these steps to restart the tracker:
12-17-2024 08:49
12-17-2024 08:49
12-23-2024 08:23
12-23-2024 08:23
Hi,
Same issue, daughters have a ace 3 fitbit each, one much dimmer then the other. Have tried the recommended solution above but unfortunately it did not work, any other suggestions please?
Thanks
Best Answer12-24-2024 11:40
12-24-2024 11:40
Welcome to our forums @CDunican. I'm sorry to hear that one of your daughters Ace 3 screen is much dimmer than the other and thank you for trying the recommended solution above. Let's try to get a solution together.
