03-13-2022 16:17
03-13-2022 16:17
2 day old ace3. Popped out of band when child playing football. Customer service advise not covered under warranty. Surely this is a design fault as I notice others with similar issues.
03-13-2022 21:03
03-13-2022 21:03
Hi @ain54 did you look where your son was playing football? If you're within 25 feet or so, the device would sync. Read this article on what to do when you've lost your Fitbit - click to go there. Also, if paid by credit card, see if they have a solution for this.
08-08-2022 15:55
08-08-2022 15:55
My daughter lost hers while camping. It sycs but ttis does not help when the device does not make a sound. Cannot find on grass and gravel. How can it just pop out of the wristband!??
Best Answer08-09-2022 11:17
08-09-2022 11:17
Hi @Armd123 did you read the article linked above on what to do when it's lost? You're close if it syncs.
Best Answer08-10-2022 11:36
08-10-2022 11:36
Yes, as mentioned pretty hard to find on grass and gravel even if it synchs — it’s still a pretty wide radius. It would help if it made a sound to narrow it down but only vibrates.
09:46
07:30
09-15-2022
09:46
07:30
Hi there, @ain54. Welcome to Community Forums.
Thanks @Odyssey13 for the support.
I appreciate the feedback provided, I'd recommend contacting our Support Team for further assistance. Also if you wish you can add a Feature Suggestion so our team can consider your suggestions, as I notice there is none entered regarding this.
I'll be around
